I've been able to design a a video that works completely using the dvdauthor suit. (one vmgm menu and one title menu)
however, when in the title menu "scenes"..there are three buttons lined up vertically and slightly off horizontally from one another (at an angle).
The problem lies in the second button down being highlighted first and not the top most button.
(3 total buttons)
the buttons themselves have their coordinates and name specified..their names containing a number at the beginning of each.
Autoorder does not seem to solve the problem, possibly one of you out there has had a similar issue.
here is the xml for the scenes menu.
<subpictures>
<stream>
<spu
force="yes"
start="00:00:00"
select="menu\scenes_click.png" highlight="menu\scenes_over.png">
<button
name="01_scenes"
x0="598" y0="168"
x1="617" y1="188"
up="03_scenes" down="02_scenes"
left="02_scenes" right="03_scenes"
<button
name="02_scenes"
x0="558" y0="318"
x1="577" y1="338"
up="01_scenes" down="03_scenes"
left="03_scenes" right="01_scenes"
<button
name="03_scenes"
x0="428" y0="394"
x1="447" y1="414"
up="02_scenes" down="01_scenes"
left="01_scenes" right="02_scenes"
</spu>
</stream>
</subpictures>
Thank you.
Just set the 'default' highlight in the dvdauthor.xml file:
If still the second button is highlighted first, try it withCode:... <menus> <video format="pal"></video> <pgc entry="title"> <pre> { button=1024; } </pre>
... { button=2048; }GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Setting button=1024 did the trick.
managed to figure this out last night before heading off to sleep.
Though your post it still very informative!!
So thank you for your efforts.
cheers!
Spumux problem
By Bigfoot73 in forum Authoring (DVD)Replies: 0Last Post: 15th Sep 2010, 15:08 -
spumux.exe
By ranee in forum Authoring (DVD)Replies: 3Last Post: 30th Jun 2010, 09:31 -
Menu button selection order in iDVD vs. Toast 10 DVDs for MAC
By HowardNeedsHelp in forum MacReplies: 0Last Post: 29th Aug 2009, 11:06 -
error with spumux.exe
By rebel14 in forum Newbie / General discussionsReplies: 2Last Post: 19th Dec 2008, 18:55 -
spumux menus and buttons alignment
By begemotv2718 in forum Authoring (DVD)Replies: 1Last Post: 3rd Aug 2008, 09:31
